transient heat flux and temperature analysis
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   3 Replies   Last post: February 14, 2013 1:57pm UTC
Mihir Velani
Mihir Velani
February 13, 2013 8:38am UTC
Dear all,
I am very new to COMSOL multiphysics.
I am doing a transient thermal analysis on geometry containing ceramic and aluminum blocks.
for the boundary conditions I need to define volumetric heat generation with respect to time, rest of the other boundary conditions like convection and initial temperature are constant.
As a result of this I want to see temperature and total heat flux for a transient having a microseconds scale.
Please help me....
appreciate all kind of help
Mihir
Ivar Kjelberg
Ivar Kjelberg
February 13, 2013 1:28pm UTC in response to Mihir Velani
Re: transient heat flux and temperature analysis
as for any other model, you need to start and proceed the same way: geoemtry, materials, physics, BC's then mesh and solve, and final postprocessing.
Now "bounday" setings are required for typically initial and fixed temperatures and sources, but a "volume source" is a domain condition and not really a "Boundary condition"
Note also that, if you are in any other size than MEMS dimensions (<1mm) then micro-second themperature effects are not really frequent and expected, fromm my knowledge (except perhaps if you are dealing with chemistry and rapid chemical reactions)
Mihir Velani
Mihir Velani
February 14, 2013 3:44am UTC in response to Ivar Kjelberg
Thank you Sir,
for your reply.
The matter is the volumetric heat generation varies with time...for example( the transient is of 0 to 50e-06 seconds)- at 1.26E-06 seconds, it is 4e12 w/m3 and 50e-06 seconds, it is 1e10 w/m3... and for this I want to check total thermal flux and temperature variation as output.
You are requested to direct me for this and if possible sir, please mention the steps..
I am deeply re grated for your inconvenience.
Mihir
Ivar Kjelberg
Ivar Kjelberg
February 14, 2013 1:57pm UTC in response to Mihir Velani
you need to define your heat shape via an analytical or a combination of step, rectangle or ramp function (Definitions - Functions, then use the correct (t[1/s]) argument when calling your function in the BC or domain variable field, and set up stepping range values such to cover your transitions and it should go.
Last: check your solver "stepping" settings and do NOT use automatic, but try intermediate or strict, check the doc
Rules and guidelines
